Spraying Nitro Lacquer
Moderator: dhlutherie
Post by Kevin in California » Tue May 05, 2026 7:50 pm
So I'm out of vinyl sealer. I've always sprayed it under the nitro because, well, I've assumed you're supposed to. Right?
Has anyone routinely skipped the sealer and just started with the lacquer, and if so how have the results been for you?
Thanks for any input.
Re: Spraying Nitro Lacquer
Post by Herman » Wed May 06, 2026 2:02 am
Never used it. Only a base coat. The results were fine.
Only when Rosewoods are involved, I seal them with shellac.
Because they tend to bleed color into the laquer.
Good luck,
Post by Kevin in California » Wed May 06, 2026 8:12 am
that's good to hear. This one is maple, spruce, sapele, mahogany. ebony, with only rosewood back strip and endwedge. I'll seal those with shellac when I pore fill them and go for the lacquer.
Thanks Buddy
Post by John Parchem » Wed May 06, 2026 10:53 am
Given that you are pore filling and sealing with shellac I suspect you can forgo the vinyl sealer.
