Tru_Oil Question
Tools and techniques
Re: Tru_Oil Question
Post by Dave Bagwill » Wed Nov 14, 2018 7:59 pm
You should be fine. I do okay and my shop has everything from bats to ufo's flying around in there...
Gibsonman
Post by Gibsonman » Thu Nov 15, 2018 9:50 am
Dave tomorrow I will begin the sanding with the 1000 grit. I know it's done very lightly with a small flat block, do I just put a drop or two of the mineral spirits right on the sandpaper it's self? Also I guess if it starts to drag a little I just add a drop or two more right?
After I am done I will just blow it off again and then start my next 3 coats of TO
On the sides instead of a block I have a small flat piece of hard rubber I can use is that ok?
Post by Dave Bagwill » Thu Nov 15, 2018 10:48 am
NOW I see what you meant by blow it off. My bad, no problem.
If you have a small spray bottle, you can spritz some mineral spirits on the to and lightly sand - just getting an even level of dullness all around. Use a clean cloth to wipe off the "schmutz" - not air.
If no spray bottle, a few drops of spirits - not much - on the body and on the sandpaper is fine. YOu'll see as you go along.
Gibsonman
Post by Gibsonman » Thu Nov 15, 2018 11:55 am
ok thanks so far I am happy with my first 3 coats. will send you a picture later on today.
Gibsonman
Post by Gibsonman » Thu Nov 15, 2018 12:57 pm
Dave I tried to post a picture, but they say it's too big pixel wise I don't know how to change that. If you have a email I can send them to you.
Gibsonman
Post by Gibsonman » Thu Nov 15, 2018 2:02 pm
you can email me and I can sent them to you
Gibsonman@comcast.net
Post by Dave Bagwill » Thu Nov 15, 2018 2:34 pm
I sent you an email.
For future pix - which we all like to see, use this easy tool: http://www.faststone.org/FSResizerDetail.htm
