I'd like to make an 8-stringer, the two lowest strings - Low C and Low D - would not be designed to be fretted.
Any suggestions as to how to approach this?
Looking for plans - 8 string guitar
Re: Looking for plans - 8 string guitar
I have taken a normal body and added a wider neck. But I fretted those two strings. You are describing a harp guitar. You can do what you are talking about with a normal sized neck with a head stock extension for the two strings. The bridge with be extended as well to the bass side, not on center.Dave Bagwill wrote: ↑Thu Apr 08, 2021 3:36 pm I'd like to make an 8-stringer, the two lowest strings - Low C and Low D - would not be designed to be fretted.
Yeah, that makes sense. Thanks.
I cannot help you here, but why a 8 string?
For the same reasons that professional players like to use them - extended range, more and easier open tunings. Somewhat like a harp guitar, essentially, but easier to make.
The real reason? Fun!!
That is a good reason.
It looks like fun to me!Dave Bagwill wrote: ↑Fri Apr 09, 2021 1:05 pm For the same reasons that professional players like to use them - extended range, more and easier open tunings. Somewhat like a harp guitar, essentially, but easier to make.
